StarTech.com 2 Port HDMI Video Splitter with Audio - USB Powered
Quicklinx: 7P2MWS00 Mfr#: ST122HDMILE
10 in stock
£37.89 ex VAT
£45.46 inc VAT
The ST122HDMILE 2-Port HDMI Video Splitter with Audio lets you share a single high definition video and audio source between two HDMI or DVI (with HDMI to DVI cable) displays. The HDMI splitter is USB-powered, making it ideal for use with desktop and laptop computers that offer HDMI output.
The USB powered high speed HDMI splitter is HDCP 1.1 compliant, delivering outstanding audio capability and flawless digital video at resolutions of up to 1080p.
To overcome connection distance limitations, the HDMI splitter also functions as an HDMI distribution amplifier allowing you to situate HDMI monitors up to 45ft (15m) away from the HDMI source - a perfect solution for connecting an HDMI-capable computer to monitors, projectors or plasma screens as needed.
StarTech.com 2 Port HDMI Video Splitter with Audio - USB Powered - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Ports
2 x HDMI
USB powered, HDCP compliant
HDCP 1.1
5.3 cm x 8.6 cm x 2 cm
120 g
Grey
1-year warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
1080p
HDCP 1.1
Status Indicators
2 x HDMI , 1 x HDMI
Grey
1 x HDMI cable - 28 cm
FCC, RoHS
5.3 cm
8.6 cm
2 cm
120 g
Limited warranty - 1 year
70 °C
0 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
7P2M StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.46
7P2M StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.58
7P2M StarTech.com 4 Port DVI Video Splitter with Audio In Stock £160.05
7P2M StarTech.com 2 Port DVI Video Splitter with Audio In Stock £80.71
7P2M StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £91.62
7P2M StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier In Stock £74.31
7P2M StarTech.com 2 Port HDMI Video Splitter with Audio - USB Powered In Stock £37.89
Price Range Ex VAT: 0 - 50
