StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card
Quicklinx: 5CCGWS00 Mfr#: EC1394B2
Type: FireWire adapter
Compatibility: PC
Interface: ExpressCard/34
21 in stock
£53.45 ex VAT
£64.14 inc VAT
This 2 Port ExpressCard FireWire Adapter Card adds two 1394b FireWire ports to a laptop computer, providing a cost-effective way to add IEEE 1394A and IEEE 1394B FireWire devices even if the laptop doesn't have a built-in FireWire 400 or FireWire 800 port. Simply insert the IEEE 1394B FireWire 800 card (EC1394B2) into an ExpressCard slot, and you'll be able to connect a broad range of FireWire devices to your laptop, while relying on data transfer speeds of up to 800Mbps. Plus, the card is backward compatible with 1394a devices, so you can connect both FireWire 400 and 800 devices to the notebook, using the same adapter.
StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card - FireWire adapter
FireWire adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
FireWire 800 x 2
3.4 cm x 12 cm x 2 cm
30 g
FireWire 800
Data Transfer Rate
800 Mbps
Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
FireWire adapter
Plug-in module
ExpressCard/34
Ports
FireWire 800 x 2
Wired
IEEE 1394b (FireWire 800)
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800
Compatible Slots
1 x ExpressCard/34
C-Tick, FCC
3.4 cm
12 cm
2 cm
30 g
Limited warranty - lifetime
5CCG StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M In Stock £7.40
5CCG StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M In Stock £15.17
Resources
The following resources are available for the StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card
Compatibility: PC
Price Range Ex VAT: 50 - 100
