Access two dual-video computers and two shared USB peripherals from a single workstation. This USB KVM lets you connect two computers, each with dual VGA outputs, to a dual-monitor workstation. You can switch the workstation between each computer, as well as two additional USB peripheral devices and 3.5mm speakers & microphone.
With support for two VGA video inputs and two different computers, this KVM switch maximizes productivity. Not only can you access multiple computers, but you can also use two VGA monitors on each computer streaming independent content to each display, which gives you the freedom to multitask and increase your productivity. The VGA ports support resolutions up to 1920x1200 for maximum screen viewing space.
Featuring dual video and support for your keyboard and mouse, along with a 2-port USB hub for two additional peripheral devices, this KVM switch is perfect for accessing two separate systems using the same workstation. Support for your workstation plus two additional peripheral devices makes this KVM ideal for server control, simplifying access to multiple computer systems.
This 2-port KVM ensures effortless operation with intuitive hotkey control. It provides a simple yet comprehensive solution for switching between each connected computer and also supports manual operation using the easy-to-access buttons located on the front of the switch.
- StarTech.com 2 Port VGA KVM Switch - Dual VGA - Hot-key & Audio Support - 1920x1200 KVM Switch - KVM Video Switch (SV231DVGAU2A) - KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub
- Power
- AC 120/230 V
- 22 cm x 13 cm x 6 cm
- 1.236 kg
- Black
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200
- Status Indicators
- Power, status
- 2 x VGA output HD-15 , 1 x audio output mini-jack , 1 x microphone output mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 2 x USB 2.0 Type A , 4 x VGA input HD-15 , 2 x microphone input mini-jack , 2 x audio input mini-jack , 2 x keyboard (USB) / mouse (USB) Type B
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- 22 cm
- 13 cm
- 6 cm
- 1.236 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.48 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £277.79 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £166.96 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £288.93 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 3.5 Right Angle Stereo Cable | In Stock | £4.19 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.59 |
StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M | In Stock | £4.43 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.16 |
StarTech.com 6 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M | In Stock | £4.36 |
StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £204.94 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £162.42 |
StarTech.com 4-port Dual VGA KVM Switch | In Stock | £176.91 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
