Product
Brand
StarTech.com 2 Port DisplayPort Video Switch with Audio & IR Remote Control
Quicklinx: 7P4HWS00 Mfr#: VS221DP
The VS221DP 2-port DisplayPort Switch offers superb multi-source control for demanding high-resolution display applications that require true high definition capability. Supporting a native display resolution of 2560x1600 and 7.1 channels of audio (when connected to supporting displays and sources), this simple, yet comprehensive DisplayPort A/V Switch features both push-button and infrared remote control and offers a compact form factor design. The VS221DP DisplayPort Video and Audio Switch delivers a reliable solution for switching between multiple DisplayPort audio/video sources.
StarTech.com 2 Port DisplayPort Video Switch with Audio & IR Remote Control - video/audio switch - 2 ports
Video/audio switch - 2 ports
Ports
2 x monitor / audio
6.5 cm x 13.1 cm x 2.6 cm
0.5 kg
2 years warranty
Enclosure Type
Desktop
Ports
2 x monitor / audio
Max Resolution
2560 x 1600 @ 60 Hz
Status Indicators
Port status
3 x DisplayPort
External power adapter
Wireless remote control
FCC, RoHS
6.5 cm
13.1 cm
2.6 cm
0.5 kg
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
7P4H StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £12.38
7P4H StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.20
7P4H StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
7P4H StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £22.13
7P4H StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £7.40
7P4H StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £11.13
