The VS221DP 2-port DisplayPort Switch offers superb multi-source control for demanding high-resolution display applications that require true high definition capability. Supporting a native display resolution of 2560x1600 and 7.1 channels of audio (when connected to supporting displays and sources), this simple, yet comprehensive DisplayPort A/V Switch features both push-button and infrared remote control and offers a compact form factor design. The VS221DP DisplayPort Video and Audio Switch delivers a reliable solution for switching between multiple DisplayPort audio/video sources.
- StarTech.com 2 Port DisplayPort Video Switch with Audio & IR Remote Control - video/audio switch - 2 ports
- Video/audio switch - 2 ports
- Ports
- 2 x monitor / audio
- 6.5 cm x 13.1 cm x 2.6 cm
- 0.5 kg
- 2-year warranty
- Enclosure Type
- Desktop
- Ports
- Max Resolution
- 2560 x 1600 @ 60 Hz
- Status Indicators
- Port status
- 3 x DisplayPort
- Power Device
- External power adapter
- Included Accessories
- Wireless remote control
- FCC, RoHS
- 6.5 cm
- 13.1 cm
- 2.6 cm
- 0.5 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.84 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £24.19 |
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.06 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
