StarTech.com 2 Port Auto High Speed HDMI Switch
Quicklinx: 7B89WS00 Mfr#: VS122HDMIU
The VS122HDMIU HDMI Auto Switcher lets you share a display between 2 consumer electronic devices or computers and prioritize your HDMI signals. The HDMI switch features a primary and secondary HDMI input port, and automatically defaults to the signal from the primary input port. If the signal connected to the primary input port is lost, the device automatically switches to display the signal from the secondary HDMI input port.
Designed for maximum control and versatility, the HDMI Auto switch box also offers manual control of connected signals with easy-to-use front panel buttons that allow you to toggle between video sources.
StarTech.com 2 Port Auto HDMI Switch - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
HDCP compliant
5.9 cm x 6.3 cm x 1.5 cm
35 g
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
1920 x 1200 / 1080p
HDCP compliant, HDTV support
Status Indicators
Port status, power
2 x HDMI , 1 x HDMI
External power adapter
FCC, RoHS
5.9 cm
6.3 cm
1.5 cm
35 g
70 °C
10 - 85%
7B89 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
7B89 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
7B89 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
