The VS122HDMIU HDMI Auto Switcher lets you share a display between 2 consumer electronic devices or computers and prioritize your HDMI signals. The HDMI switch features a primary and secondary HDMI input port, and automatically defaults to the signal from the primary input port. If the signal connected to the primary input port is lost, the device automatically switches to display the signal from the secondary HDMI input port.
Designed for maximum control and versatility, the HDMI Auto switch box also offers manual control of connected signals with easy-to-use front panel buttons that allow you to toggle between video sources.
- StarTech.com 2 Port Auto HDMI Switch - video/audio switch - 2 ports
- Video/audio switch - 2 ports
- Subtype
- HDMI
- Ports
- 2 x HDMI
- HDCP compliant
- 5.9 cm x 6.3 cm x 1.5 cm
- 35 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 2 x HDMI
- Max Resolution
- 1920 x 1200 / 1080p
- HDCP compliant, HDTV support
- Status Indicators
- Port status, power
- 2 x HDMI , 1 x HDMI
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 5.9 cm
- 6.3 cm
- 1.5 cm
- 35 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 85%
