StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch – USB Powered
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8Y6MWS00 Mfr#: USB221SS
Ports: 2
34 in stock
£24.75 ex VAT
£29.70 inc VAT
Share a single USB 3.0 device between two different computers. The USB221SS 2-to-1 USB 3.0 Peripheral Sharing Switch lets you share a single USB 3.0 peripheral with 2 different computer systems, avoiding the cost of purchasing duplicate peripherals or the hassle of swapping cables from one system to another.
The USB sharing switch delivers speed and flexibility, with simple push-button controls for switching between computers, and support for SuperSpeed USB bandwidth (up to 5 Gbps) ensuring fast data transfers to/from your shared peripheral device. The switch is also backward compatible with USB 2.0/1.1 (480Mbps, 12Mbps respectively), so you don't have to worry about your computer or older peripherals not performing.
The 2-port USB switch can also be connected to a USB hub, to expand the number of devices you can share between the two connected systems, or to a USB drive enclosure or docking station, for a shared external storage solution.
The switch features a compact design that takes up minimal desk space and is USB-powered, so it doesn't require an AC wall outlet.
StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch - USB peripheral sharing switch - 2 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0
USB powered
USB 2.0, USB 3.0
4.2 cm x 6.9 cm x 2.2 cm
40 g
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
USB 2.0, USB 3.0
2 x USB 3.0 Type B , 1 x USB 3.0 Type A
1 x SuperSpeed USB cable - 1 m
FCC, RoHS
4.2 cm
6.9 cm
2.2 cm
40 g
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8Y6M StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £2.92
8Y6M StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.40
8Y6M StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB over IP Device Server In Stock £67.22
8Y6M StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.66
8Y6M StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £30.13
8Y6M StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £30.85
8Y6M StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £48.59
8Y6M StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch – USB Powered In Stock £24.75
Ports: 2
Price Range Ex VAT: 0 - 50
