Add two extra serial ports to the back of your PC, from your motherboard. The PLATE9M2P16 Dual Port Serial Plate adds two DB9 serial ports to the rear panel of a computer, connecting to two IDC10 header connectors on the motherboard.
Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
- StarTech.com 2 Port 16in DB9 Serial Port BRacket to 10 Pin Header - DB9 bRacket - DB9 Header - Serial Port bRacket (PLATE9M2P16) - serial panel - DB-9 to 10 PIN IDC - 40.64 cm
- Serial panel
- Length
- 40.64 cm
- Connector
- 2 x 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 2 x 10 PIN IDC - female
- Grey
- Limited lifetime warranty
- Serial panel
- American Wire Gauge (AWG)
- 28
- Length
- 40.64 cm
- Grey
- Connector
- RoHS
