StarTech.com 2 Port 1394a PCI Express FireWire Card - PCIe FireWire Adapter
Quicklinx: 99BTWS00 Mfr#: PEX1394A2V
  • Windows 8 (32/64 bits)
Add 2 native FireWire 400 ports to your desktop through a PCI Express slot. The PEX1394A2V 2-Port PCI Express FireWire Card lets you add two native FireWire 400 ports to your desktop PC, allowing you to connect IEEE 1394A FireWire devices such as digital cameras, external hard drives, DV camcorders, and more.
When two devices are simultaneously connected, this PCIe FireWire adapter reduces performance bottlenecks by offering support for data transfer rates up to 400Mbps to each port. The FireWire card employs dual-bus architecture to provide the maximum bandwidth to each individually connected device, rather than sharing the bandwidth across multiple ports.
An ideal solution for transferring large volumes of data at once, the FireWire card also integrates a native PCIe single chipset design. With no secondary bridge chipset, your FireWire devices communicate quicker with your PC to ensure seamless operation of your connected peripherals.
For broad compatibility, the FireWire card is natively supported in Windows with no additional drivers required, is equipped with a standard profile bracket, and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com 2 Port 1394a PCI Express FireWire Card - PCIe FireWire Adapter - FireWire adapter
FireWire adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
FireWire x 2
1.8 cm x 6.7 cm x 6 cm
38 g
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux 2.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
FireWire adapter
PCI Express x1
Ports
FireWire x 2
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
400 Mbps
2 x FireWire - 6 PIN FireWire
Low-profile bracket
FCC, RoHS
1.8 cm
6.7 cm
6 cm
38 g
Limited warranty - lifetime
85 °C
20 - 80%
99BT StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal In Stock £12.59
99BT StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit In Stock £40.31
99BT StarTech.com 2 Port ExpressCard Laptop 1394a Firewire Adapter Card In Stock £34.73
99BT StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £46.20
99BT StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter In Stock £46.20
99BT StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M In Stock £7.27
