Add 2 native FireWire 400 ports to your desktop through a PCI Express slot. The PEX1394A2V 2-Port PCI Express FireWire Card lets you add two native FireWire 400 ports to your desktop PC, allowing you to connect IEEE 1394A FireWire devices such as digital cameras, external hard drives, DV camcorders, and more.
When two devices are simultaneously connected, this PCIe FireWire adapter reduces performance bottlenecks by offering support for data transfer rates up to 400Mbps to each port. The FireWire card employs dual-bus architecture to provide the maximum bandwidth to each individually connected device, rather than sharing the bandwidth across multiple ports.
An ideal solution for transferring large volumes of data at once, the FireWire card also integrates a native PCIe single chipset design. With no secondary bridge chipset, your FireWire devices communicate quicker with your PC to ensure seamless operation of your connected peripherals.
For broad compatibility, the FireWire card is natively supported in Windows with no additional drivers required, is equipped with a standard profile bracket, and includes a low-profile/half-height bracket for installation in small form-factor computers.
- StarTech.com 2 Port 1394a PCI Express FireWire Card - PCIe FireWire Adapter - 1394a FireWire PCI Express - Dual Port PCIe 400 Card (PEX1394A2V) - FireWire adapter - PCIe - FireWire x 2
- FireWire adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- FireWire x 2
- 1.8 cm x 6.7 cm x 6 cm
- 38 g
- Data Link Protocol
- Firewire
- Data Transfer Rate
- 400 Mbps
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux 2.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- FireWire adapter
- Form Factor
- PCI Express x1
- Ports
- FireWire x 2
- Connectivity Technology
- Wired
- IEEE 1394 (FireWire)
- 400 Mbps
- 2 x FireWire - 6 PIN FireWire
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- OS Required
- 1.8 cm
- 6.7 cm
- 6 cm
- 38 g
- Limited warranty - lifetime
- 0 °C
- 85 °C
- 20 - 80%
StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal | In Stock | £19.41 |
StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit | In Stock | £48.06 |
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £55.09 |
StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M | In Stock | £7.62 |
