StarTech.com 2 Port 10G NIC w/ Chassis
Quicklinx: DXG6WS00 Mfr#: BNDTB310GNDP
18 in stock
£442.11 ex VAT
£530.53 inc VAT
This Thunderbolt 3 PCIe expansion chassis lets you connect your Thunderbolt 3 enabled device to a 10 Gigabit Ethernet network via an external PCIe enclosure. This Thunderbolt 3 to 10GbE NIC lets you connect your Thunderbolt 3 enabled device to a 10 Gigabit Ethernet network. This adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the 2-port PCI Express 10G NIC (ST10GPEXNDPI), giving you one DisplayPort output, one additional Thunderbolt 3 port and two 10GbE ports.
This 10G network card utilizes the Intel X550 chipset with Intel Virtualization Technology (Microsoft Hyper-V) for connectivity, delivering the power, performance and enhanced capabilities you need for dependable network connections.
Requiring only a Phillips type screwdriver, you can assemble this Thunderbolt 3 to 10GbE NIC chassis in minutes. It connects easily through a single Thunderbolt 3 port on your computer.
The Thunderbolt 3 chassis not only pairs well with the 10GbE NIC - the card can be swapped for other PCIe cards to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to multitask effortlessly.
  • Reliable, high-performance and versatile multimode connectivity
  • Install and assemble with ease
  • Change up your chassis
StarTech.com Thunderbolt 3 to 2-port 10GbE NIC Chassis - network adapter
Network adapter
Plug-in card - low profile
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0
Ports
1/2.5/5/10GBase-T x 2
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
Data Transfer Rate
10 Gbps
Jumbo frame size: 9000
X550-AT - Intel
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3q
Microsoft Windows 7 / 8 / 8.1 / 10, Windows 10 / Windows Server 2012 / Windows Server 2016, Microsoft Windows Server 2008 / 2012 R2, Linux 3.x - 4.11 LTS versions
Network adapter
Bundled with
PCI Express 3.0 x4
PCIe 3.0
Ports
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
X550-AT - Intel
2 x 1/2.5/5/10GBase-T - RJ-45 - female
Low-profile bracket
1 x Thunderbolt 3 / USB-C cable (external) - 50 cm
FCC, RoHS, WEEE
5 °C
20 - 80%
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Type: Network adapter
Price Range Ex VAT: 300 - 500
