StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD
Quicklinx: 9FSZWS00 Mfr#: S2510BPU337
Type: Storage enclosure
HD Size: 2.5"
  • Windows 8 (32/64 bits)
32 in stock
£15.51 ex VAT
£18.61 inc VAT
Turn a 7mm high 2.5in SATA III SSD/HDD into a UASP-supported USB 3.0 External Drive. This slim, pocket-sized drive enclosure is specifically engineered for 7mm drives, giving you the option to turn your thin hard drive or solid state drive into an external storage solution connected through UASP-enabled USB 3.0. With a thin yet durable design, the enclosure fits your 7mm drives perfectly to eliminate any drive movement inside the enclosure, which could be a problem with a looser-fitting enclosure.
To help save you time transferring data to and from your 7mm SSD or HDD, this UASP-enabled enclosure supports transfer speeds up to 70% faster than traditional USB 3.0, when used with a UASP-enabled host computer.
Plus, the enclosure is USB-powered, so you don't have to carry a power adapter with you, giving you one less thing to pack when you're traveling.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD / HDD - 7mm 2.5" Drive Enclosure - SATA 6 Gbps (S2510BPU337) - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic
Power Source
USB bus
Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
9.1 cm x 9.5 cm x 14.4 cm
45 g
2.5"
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
1
ASMedia
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin Micro-USB Type B
1 x USB 3.0 cable - external
Mounting Kit
Included
FCC, RoHS
Power Source
USB bus
9.1 cm
9.5 cm
14.4 cm
45 g
10 - 95%
9FSZ StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £29.00
9FSZ StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £24.08
9FSZ StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.45
9FSZ StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £6.32
9FSZ StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £5.95
9FSZ StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £30.15
9FSZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.94
9FSZ StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £16.56
9FSZ StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP In Stock £15.51
9FSZ StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.15
9FSZ StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD In Stock £15.51
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
