StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure - 9.5/12.5mm HDD
Quicklinx: 7RXBWS00 Mfr#: SAT2510B12U3
Turn a 2.5in SATA Hard Drive (9.5mm or 12.5mm) into a Portable USB 3.0 External Hard Drive. The SAT2510B12U3 USB 3.0 External SATA Hard Drive Enclosure lets you connect a 2.5in (SATA, SATA II, SATA III) hard drive or solid state drive (SSD) through USB 3.0. Uniquely designed to be able to fit both 9.5mm and high capacity 12.5mm height hard drives for compatibility with virtually any available SATA hard drive. Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Supporting data transfer rates of up to 5 Gbps, this external HDD enclosure delivers access to files at lightning fast speeds - 10x that of USB 2.0, and 60% faster than SATA II eSATA. Plus, the USB 3.0 interface is backward compatible with USB revisions 2.0 and 1.1, so the enclosure can be used with older systems that don't support the newest USB standard (at speeds of 480Mbps and 12 Mbps, respectively).
StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure - storage enclosure - SATA 3Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
USB bus
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista / XP / 7 / 8
13.8 cm x 1.7 cm x 7.7 cm
189 g
2.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1051
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA combo
1 x USB 3.0 - 10 pin Micro-USB Type B
Tested with up to 1TB 5400 RPM hard drives
FCC, RoHS
Power Source
USB bus
13.8 cm
1.7 cm
7.7 cm
189 g
60 °C
10 - 90%
7RXB StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.42
