StarTech.com 2.5in to 3.5in IDE Hard Drive Cable Adapter
Customer rating: 5.0* (Write a review)
Quicklinx: 3ZLSWS00 Mfr#: IDE4044
This 2.5in to 3.5in IDE Hard Drive Adapter cable provides a 44-pin female IDE connector and a 40-pin male IDE connector as well as an LP4 power supply connection, allowing you to connect a 2.5in IDE laptop hard drive to a desktop computer.
StarTech.com 2.5in to 3.5in IDE Hard Drive Cable Adapter - IDE / EIDE adapter
IDE / EIDE adapter
Connectors
44 PIN IDC - female
Connectors (Second End)
40 PIN IDC - male , Power 4-pole - male
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, UNIDOCKU33
Storage Cable Type
IDE / EIDE adapter
Connectors
44 PIN IDC - female
Customer reviews
Write a review for the StarTech.com 2.5in to 3.5in IDE Hard Drive Cable Adapter here!
Perfect!
Reviewed by Pete. Review Posted 08/04/2008
This has to be the best buy i have ever done. Easy to use, cheap and delivery was fast: ordered friday, arrived Tuesday! I had a few problems at first but they were my own fault. Just glad to have my old files back. THANK YOU DABS! I Recommend if you need a converter for an old laptop HDD
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very good
Reviewed by Andrew. Review Posted 22/01/2007
Does exactly what it says on the tin!
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
