StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter
Quicklinx: 7TGLWS00 Mfr#: 25SATSAS35
29 In Stock
£14.59 ex VAT
£17.50 inc VAT
Turn Virtually any 2.5" SATA or SAS Hard Drive into a 3.5" SATA Drive. The 25SATSAS35 2.5-inch SATA/SAS to 3.5-inch SATA Hard Drive Converter converts a 2.5-inch SATA or SAS hard drive (HDD) or solid state drive (SSD) into a 3.5-inch form factor SATA Hard Drive.
The converter provides a versatile solution for 2.5-inch drive installations, enabling you to install a 2.5-inch SATA/SAS drive in a 3.5-inch bay, drive drawer caddy/tray, or into a 3.5-inch drive enclosure.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Suitable for drives with a height of up to 15mm, virtually any 2.5-inch SATA or SAS hard drive can be made to look and function like a 3.5-inch hard drive - complete with standard mounting points along the sides and bottom (including 3 points along the sides for compatibility with some Dell systems).
The Drive Converter features a trayless design for simple drive installation and removal, and is constructed of durable, yet lightweight plastics, with ventilation openings to aid air flow and help keep hard drives running cooler.
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter - Storage bay adapter - 3.5" to 2.5" - black - 25SATSAS35 - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Plastic
10.1 cm x 14.6 cm x 2.5 cm
135 g
P/N: IDE2SAT2, S352BU33HR, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
Storage bay adapter
3.5" to 2.5"
Product Material
Plastic
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
FCC, RoHS
10.1 cm
14.6 cm
2.5 cm
135 g
