StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot
Quicklinx: 6604WS00 Mfr#: S25SLOTR
10 In Stock
£26.17 ex VAT
£31.40 inc VAT
Use an available expansion card slot to install a hot swappable 2.5in hard drive. The S25SLOTR Trayless Hard Drive Rack can be installed into an available (full profile) PCI expansion card slot, providing easy access to a bare 2.5" SATA hard drive or solid state drive (SSD) from the rear panel of a computer case.
Unlike conventional hard drive enclosures, the S25SLOTR hard drive rack doesn't require that a drive be installed in a drive tray, saving the time and hassle involved in having to mount or install the hard drive for access to drive contents.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Once installed in a PCI slot (and accompanying rear panel bracket), installing a 2.5" SATA HDD is as simple as inserting it into the trayless rack. To remove the hard drive, simply hit the eject button to unlock the access door, allowing the drive to be pulled out of the computer without having to dismount the drive.
This unique design of the mobile rack enables you to use any available full profile expansion slot to mount a removable 2.5in SATA hard drive.
StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot - Storage bay adapter - black - S25SLOTR - storage bay adapter
Storage bay adapter
Expansion Bays
1 x hot-swap - 2.5"
Product Material
Aluminium, steel
14.5 cm x 2.1 cm x 12 cm
158 g
Storage bay adapter
Product Material
Aluminium, steel
Bays
1 x hot-swap - 2.5"
1 x SATA 3Gb/s - SATA combo
1 storage - Serial ATA-300 - 22 pin Serial ATA
Compatible Slots
1 x PCI
1 x Serial ATA cable - internal
FCC, RoHS
14.5 cm
2.1 cm
12 cm
158 g
55 °C
0 - 80%
6604 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.49
6604 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.06
6604 StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
6604 StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.71
6604 StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £43.75
6604 StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £26.17
6604 StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 In Stock £3.78
6604 StarTech.com M.2 NVMe SSD to PCIe x4 Slot In Stock £77.11
6604 StarTech.com Dual M.2 NVMe SSD to PCIe x8 In Stock £135.29
