StarTech.com 2.5in Black USB 2.0 External Hard Drive Enclosure for SATA HDD
Quicklinx: 67CNWS00 Mfr#: SAT2510BU2
  • Windows 8 (32/64 bits)
Turn a 2.5in SATA drive into an external storage device with USB 2.0 connectivity. This external hard drive enclosure transforms a 2.5in SATA (SATA, SATA II, SATA III) hard drive or SSD into the perfect portable storage solution.
Ideal for storing digital multimedia and other demanding applications, the enclosure lets you get the most out of your hard drive, connecting to a host computer using USB 2.0 (also backward compatible with USB 1.1), for maximum data transfer rates of 480Mbps. Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Plus, the external hard drive enclosure includes a USB Y-cable, that when both USB male connectors are connected to the host computer eliminates the need for an external power adapter.
StarTech.com 2.5in Black USB 2.0 External Hard Drive Enclosure for SATA HDD - storage enclosure - SATA 3Gb/s - USB 2.0
Storage enclosure - external
Bus Type
USB 2.0
Piano black
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
Additional USB, USB bus
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
7.5 cm x 12 cm x 1 cm
62 g
2.5"
Host Bus
USB 2.0
Product Material
Aluminium
Piano black
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
No CPU
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA
1 x USB 2.0 - mini-USB Type B
Pouch
1 x USB cable - external
Tested with up to 1TB 5400 RPM hard drives
Mounting Kit
Included
FCC, RoHS
Power Source
Software Included
Drivers & Utilities
7.5 cm
12 cm
1 cm
62 g
67CN StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B In Stock £4.95
