Turn a 2.5in SATA hard drive into a USB2.0 or eSATA external hard drive. This eSATA/USB External Hard Drive Enclosure transforms virtually any 2.5" SATA (SATA, SATA II, SATA III) hard drive or solid state drive (SSD) into a cost-effective portable storage solution.
Ideal for storing digital multimedia and other demanding applications, the 2.5" SATA hard drive enclosure connects to a host computer using USB 2.0 or eSATA with support for data transfer rates of up to 3Gbps (using eSATA) or 480Mbps (through USB 2.0). Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
A truly portable solution, the compact hard drive enclosure features lightweight yet durable aluminum construction, as well as a small form factor design that fits perfectly into your pocket or notebook bag when not in use. To eliminate the hassle of having to find a power outlet when you are ready to back up data or load your stored files, the USB/eSATA enclosure offers USB-powered operation, requiring no external power supply.
- StarTech.com 2.5in Black eSATA USB External Hard Drive Enclosure for SATA HDD - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
- Storage enclosure - external
- Bus Type
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Product Material
- Aluminium
- Power Source
- USB bus
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- 7.2 cm x 13.3 cm x 1.3 cm
- 90 g
- 2-year warranty
- Designed For
- P/N: SATDUP11IMG
- 2.5"
- Host Bus
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- Processor
- JMicron JM20316
- Bays
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 2.0 - mini-USB Type B , 1 storage - eSATA-300 - 7 pin external Serial ATA
- Cables Included
- 1 x USB cable - external , 1 x eSATA cable - external
- Tested with up to 1TB 5400 RPM hard drives
- FCC
- Power Source
- USB bus
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 7.2 cm
- 13.3 cm
- 1.3 cm
- 90 g
- Designed For
- P/N: SATDUP11IMG
