Turn a 2.5" SATA HDD/SSD into a 3.5" SATA Drive. The 25SAT35HDD 2.5" to 3.5" hard drive adapter enclosure turns a 2.5" SATA hard drive (HDD) or solid state drive (SSD) into a 3.5" drive.
The adapter enclosure lets you substitute a 3.5" hard drive for a 2.5" SSD/HDD in any application that would typically require a 3.5" drive, such as desktop chassis, backplane, or docking station. The enclosure has the same dimensions as a standard 3.5" hard drive, including mounting points, and SATA connector locations.
With support for drives up to 12.5mm in height, and high-capacity SATA I/II/III drives (tested up to 1TB) this HDD adapter ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
- StarTech.com 2.5" to 3.5" SATA HDD/SSD Adapter Enclosure - External Hard Drive Converter with HDD/SSD Height up to 12.5mm (25SAT35HDD) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s
- Storage enclosure - internal
- Bus Type
- SATA 6Gb/s
- Expansion Bays
- 1 x internal - 2.5" x 1/8H
- Compatible Bay
- 1 3.5" x 1/3H
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600
- Drive Connector
- 22 pin Serial ATA
- Bay Connector
- 22 pin Serial ATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic, aluminium
- 10.2 cm x 14.6 cm x 3.6 cm
- 260 g
- 2-year warranty
- Designed For
- P/N: S352BU33HR
- 2.5"
- Host Bus
- SATA 6Gb/s
- Product Material
- SATA-600
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 - 22 pin Serial ATA
- Compatible Bay
- 1 x internal 3.5" x 1/3H
- Cables Included
- 1 x Serial ATA cable
- Tested with up to 1TB 7200 RPM 2.5" hard drives
- FCC, RoHS
- Limited warranty - 2 years
- 10.2 cm
- 14.6 cm
- 3.6 cm
- 260 g
- Shipping Width
- 11.5 cm
- Shipping Depth
- 16.3 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 260 g
- 5 °C
- 55 °C
- 5 - 85%
- Designed For
- P/N: S352BU33HR
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.39 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £5.24 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.38 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £20.67 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.07 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £26.01 |
