StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm
Quicklinx: 9657WS00 Mfr#: 25SAT35HDD
Type: Adapter
32 in stock
£16.37 ex VAT
£19.64 inc VAT
Turn a 2.5" SATA HDD/SSD into a 3.5" SATA Drive. The 25SAT35HDD 2.5" to 3.5" hard drive adapter enclosure turns a 2.5" SATA hard drive (HDD) or solid state drive (SSD) into a 3.5" drive.
The adapter enclosure lets you substitute a 3.5" hard drive for a 2.5" SSD/HDD in any application that would typically require a 3.5" drive, such as desktop chassis, backplane, or docking station. The enclosure has the same dimensions as a standard 3.5" hard drive, including mounting points, and SATA connector locations.
With support for drives up to 12.5mm in height, and high-capacity SATA I/II/III drives (tested up to 1TB) this HDD adapter ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
StarTech.com 2.5" SSD/HDD to 3.5" SATA Aluminum HDD Adapter Enclosure - storage enclosure - SATA 6Gb/s - SATA 6Gb/s
Storage enclosure - internal
Bus Type
SATA 6Gb/s
Expansion Bays
1 x internal - 2.5" x 1/8H
Compatible Bay
1 3.5" x 1/3H
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600
Drive Connector
22 pin Serial ATA
Bay Connector
22 pin Serial ATA
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic, aluminium
10.15 cm x 4.75 cm x 2.55 cm
216 g
2.5"
Host Bus
SATA 6Gb/s
Product Material
Plastic, aluminium
Supported Interface
SATA-600
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Bays
1 x SATA 6Gb/s
1 - 22 pin Serial ATA
Compatible Bay
1 x internal 3.5" x 1/3H
1 x Serial ATA cable
Tested with up to 1TB 7200 RPM 2.5" hard drives
FCC, RoHS
10.15 cm
4.75 cm
2.55 cm
216 g
5 °C
55 °C
5 - 85%
9657 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
9657 StarTech.com 18in SATA Serial ATA Cable In Stock £3.35
9657 StarTech.com 36in SATA Serial ATA Cable In Stock £3.15
9657 StarTech.com SATA to LP4 Power Cable Adapter In Stock £4.35
9657 StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £14.58
9657 StarTech.com 4 Drive 3.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £73.23
9657 StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack for SATA HDD/SSD In Stock £39.38
9657 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £16.37
9657 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £64.25
Type: Adapter
Price Range Ex VAT: 0 - 50
