Easily install one 2.5" solid-state drive or hard drive into a 3.5" bay, without requiring any additional hardware or tools. This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height.
The mounting bracket's tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It's ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects.
The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs.
- StarTech.com 2.5" HDD / SDD Mounting Bracket for 3.5" Drive Bay - Tool-less Installation - 2.5 Inch SSD HDD Adapter Bracket (BRACKET125PT) - storage bay adapter
- Storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Plastic
- 10.2 cm x 15 cm x 1.3 cm
- 35 g
- 2-year warranty
- Designed For
- P/N: M2E4SFF8643, PEX4SFF8643, U2M2E125
- 3.5" to 2.5"
- Product Material
- Plastic
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- Included Accessories
- 6 plastic pegs
- RoHS, WEEE
- Limited warranty - 2 years
- 10.2 cm
- 15 cm
- 1.3 cm
- 35 g
- Designed For
