StarTech.com 2.5" SATA Drive Hot Swap Bay
Quicklinx: D28LWS00 Mfr#: SATBP125VP
Hot swap drives in the front bay of your computer or server, and safeguard your data with anti-vibration protection. Increase the storage capabilities of your server or PC while protecting your data, with this 2.5" SATA drive hot-swap bay.
Turn the 3.5" front bay on your desktop computer or server into a hot-swap bay for 2.5" SATA SSD/HDD drives. Ideal for IT professionals, such as system administrators or computer operators, this mobile rack lets you quickly swap, replace, remove, or transport a drive between systems or locations. It saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers.
The 2.5" SATA drive hot-swap bay provides a protective backplane with a durable aluminum housing that offers ventilation to ensure proper air flow and heat dissipation. It features four anti-vibration bumpers, to protect your drive against vibration damage. To safeguard your data, you can lock the drive bay door to prevent unauthorized access to your drive
To maximize the speed and performance of your drives, the mobile rack supports SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
StarTech.com 2.5 SATA Drive Hot Swap Bay - for 3.5" Front Bay - Anti-Vibration - Front Mount Design - Hard Drive Caddy - Hard Drive Rack (SATBP125VP) - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x hot-swap - 2.5"
Compatible Bay
1 3.5"
Key lock, vibration protection
Product Material
Plastic, aluminium
10.16 cm x 13.5 cm x 2.5 cm
304 g
Storage bay adapter
3.5" to 2.5"
Hard Drive Maximum Height
15 mm
Product Material
Plastic, aluminium
Storage Controller
No CPU
Bays
1 x hot-swap - 2.5"
1 x SAS - 29 pin internal SAS (SFF-8482)
1 x SATA 6Gb/s - 22 pin Serial ATA
Compatible Bay
1 x drive cage 3.5"
2 security keys, screws
1 x Serial ATA cable
LED indicator, ventilation holes
10.16 cm
13.5 cm
2.5 cm
304 g
-40 °C
85 °C
5 - 65%
D28L StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.58
D28L StarTech.com 24" Serial ATA Cable In Stock £5.26
D28L StarTech.com 36in SATA Serial ATA Cable In Stock £5.68
D28L StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.44
D28L StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £26.17
D28L StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.62
D28L StarTech.com 12in SATA Serial ATA Cable In Stock £4.44
D28L StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.36
D28L StarTech.com 4-Bay Backplane for SSD/HDD In Stock £79.56
D28L StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.62
