The S2510SM12U33 USB 3.0 to SATA hard drive enclosure with UASP enables you to connect a 2.5" SATA hard drive or solid state drive to your computer through an available USB port.
With support for drives up to 12.5 mm in height, and high-capacity SATA I/II/III drives, this versatile USB 3.0 enclosure ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
To maximize performance and better utilize the full potential of your SATA III SSD/HDD the enclosure supports UASP, which allows for transfer speeds up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The USB 3.0 enclosure features a sleek design with high-quality aluminum construction and ventilation, ensuring excellent heat dissipation. The S2510SM12U33 requires no external power adapter to maximize portability.
- StarTech.com 2.5" Aluminum USB 3.0 SATA III Hard Drive Enclosure w/ UASP - SSD/HDD Height - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Silver
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 5 GBps
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- USB bus
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 7.8 cm x 12.5 cm x 2.4 cm
- 126 g
- 2-year warranty
- Designed For
- P/N: DK30BACDD, DK30CHDDPPD, DK30CHDPPDUE, PEXUSB3S24, USB3DOCKHDPC, USB3SDOCKDD
- 2.5"
- Hard Drive Maximum Height
- 12.5 mm
- Host Bus
- USB 3.0
- Product Material
- Aluminium
- Silver
Storage Controller
- Interface
- SATA 6Gb/s
- 5 GBps
- Supported Devices
- Hard drive
- 1
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Included Accessories
- HDD pad
- Cables Included
- 1 x USB cable - external
- USB powered, LED indicator
- FCC, RoHS
- Power Source
- USB bus
- OS Required
- Limited warranty - 2 years
- 7.8 cm
- 12.5 cm
- 2.4 cm
- 126 g
- 5 °C
- 35 °C
- 5 - 95%
- Designed For
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.42 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £25.64 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £36.81 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £20.71 |
