StarTech.com 2.5" Aluminum USB 3.0 SATA III Hard Drive Enclosure w/ UASP SSD/HDD Height up to 12.5mm
Quicklinx: 9656WS00 Mfr#: S2510SM12U33
  • Windows 8 (32/64 bits)
The S2510SM12U33 USB 3.0 to SATA hard drive enclosure with UASP enables you to connect a 2.5" SATA hard drive or solid state drive to your computer through an available USB port.
With support for drives up to 12.5 mm in height, and high-capacity SATA I/II/III drives, this versatile USB 3.0 enclosure ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
To maximize performance and better utilize the full potential of your SATA III SSD/HDD the enclosure supports UASP, which allows for transfer speeds up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The USB 3.0 enclosure features a sleek design with high-quality aluminum construction and ventilation, ensuring excellent heat dissipation. The S2510SM12U33 requires no external power adapter to maximize portability.
StarTech.com 2.5" Aluminum USB 3.0 SATA III Hard Drive Enclosure w/ UASP - SSD/HDD Height - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Silver
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Aluminium
Power Source
USB bus
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
7.8 cm x 12.5 cm x 2.4 cm
126 g
P/N: DK30BACDD, DK30CHDDPPD, DK30CHDPPDUE, PEXUSB3S24, USB3DOCKHDPC, USB3SDOCKDD
2.5"
Hard Drive Maximum Height
12.5 mm
Host Bus
USB 3.0
Product Material
Aluminium
Silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
1
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 10 pin Micro-USB Type B
HDD pad
1 x USB cable - external
USB powered, LED indicator
FCC, RoHS
Power Source
USB bus
7.8 cm
12.5 cm
2.4 cm
126 g
5 °C
35 °C
5 - 95%
9656 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.42
9656 StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £25.64
9656 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £36.79
9656 StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £20.71
