Turn four 3.5" SATA/SAS drives into a 1U rack-mountable storage solution with external Mini SAS connectivity. The SAT35401U Rack-mountable 4-bay trayless HDD enclosure enables you to mount and hot-swap up to four 3.5" SATA or SAS hard drives into 1U of rack/cabinet storage space.
To ensure maximum performance and versatility, the enclosure offers support for SATA/SAS HDD speeds up to 6.0 Gbps with a mini SAS interface and is fully compatible with RAID controllers for enhanced storage applications.
The rugged steel rack-mountable chassis with 3 built-in fans makes it an ideal solution for any server environment that requires hot-swappable storage.
- StarTech.com 1U Rackmount 4-Bay 3.5" SATA/SAS External Hard Drive Enclosure - hard drive array
- Hard drive array
- Black
- Interface
- SAS 6Gb/s
- Installed Devices / Modules Qty
- 4 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- SATA/SAS-2 (SATA 6Gb/s / SAS 6Gb/s)
- Hard Drive
- 0 HDD - hot-swap
- OS Required
- Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
- Power
- AC 120/230 V
- 30.2 cm x 44 cm x 5.35 cm
- 5.8 kg
- 2-year warranty
- Designed For
- P/N: SVA12DN4NEUA
- Hard drive array
- Enclosure Colour
- Black
Chassis
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- SAS 6Gb/s
Storage Controller
- SATA/SAS-2
- Channel Qty
- 4
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 3.5"
- 1 x SAS 6Gb/s
- OS Required
- Built-in 3 cooling fans
- Mounting Kit
- Included
- WHQL, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 30.2 cm
- 44 cm
- 5.35 cm
- 5.8 kg
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80%
- Designed For
- P/N: SVA12DN4NEUA
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.92 |
StarTech.com 1m External Mini SAS Cable - Serial Attached SCSI SFF-8088 to SFF-8088 | In Stock | £61.33 |
StarTech.com 2m External Mini SAS Cable - Serial Attached SCSI SFF-8088 to SFF-8088 | In Stock | £66.04 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £14.59 |
StarTech.com 3m External Mini SAS Cable - Serial Attached SCSI SFF-8088 to SFF-8088 | In Stock | £98.67 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.52 |
