Mount the SV841DUSBI KVM switch into a standard server rack, in either a one or two-across configuration. The 841RACKBRKT 1U Rack Mount Brackets for the SV841DUSBI KVM Switch let you mount your SV841DUSBI IP KVM into a standard server rack.
Designed for simple installation and versatility, this rack mount kit includes the required pieces to mount either a single KVM in your rack, or mount two KVMs across the rack in a two-across (side-by-side) configuration. Works with the StarTech.com 8 Port USB VGA IP KVM Switch (SV841DUSBI).
- StarTech.com 1U Rack Mount Brackets - rack bracket kit - 1U
- Product Type
- Rack bracket kit
- Package Content
- Long bracket, short bracket
- 381 g
- Black
- Height (Rack Units)
- 1U
- RoHS
- 2-year warranty
- Designed For
- StarTech.com 8 Port USB VGA IP KVM Switch with Virtual Media
- Product Type
- Rack bracket kit
- Package Content
- 1U
- 381 g
- Enclosure Colour
- Black
- Rack Mounting Kit
- Included
- RoHS
- Limited warranty - 2 years
- Designed For
