Your basket is empty
StarTech.com 1U Rack Mount Brackets for the SV841DUSBI KVM Switch
Quicklinx: B142WS00 Mfr#: 841RACKBRKT
Mount the SV841DUSBI KVM switch into a standard server rack, in either a one or two-across configuration. The 841RACKBRKT 1U Rack Mount Brackets for the SV841DUSBI KVM Switch let you mount your SV841DUSBI IP KVM into a standard server rack.
Designed for simple installation and versatility, this rack mount kit includes the required pieces to mount either a single KVM in your rack, or mount two KVMs across the rack in a two-across (side-by-side) configuration. Works with the StarTech.com 8 Port USB VGA IP KVM Switch (SV841DUSBI).
StarTech.com 1U Rack Mount Brackets - rack bracket kit - 1U
Rack bracket kit
Package Content
Long bracket, short bracket
381 g
Height (Rack Units)
1U
RoHS
2 years warranty
StarTech.com 8 Port USB VGA IP KVM Switch with Virtual Media
Rack bracket kit
Package Content
Height (Rack Units)
1U
381 g
Enclosure Colour
Rack Mounting Kit
Included
RoHS
