StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg
Quicklinx: 8875WS00 Mfr#: ADJSHELFHDV
Product Type: Rack shelf, Rack shelf
Hurry, only 3 left in stock!
£80.11 ex VAT
£96.13 inc VAT
Add a high capacity, adjustable depth vented shelf into almost any server rack or cabinet. The ADJSHELFHDV 1U Adjustable Heavy Duty Vented Rack Mount Shelf lets you add a high-capacity, adjustable 1U shelf to virtually any standard 19-inch server rack or cabinet.
This heavy duty rackmount shelf can be adjusted from 19.5in to 38in (mounting depth) to fit your rack, while the vented design improves air flow and help to lower temperatures in the rack. Constructed using 1.2mm SPCC commercial grade cold-rolled steel, providing the ability to hold up to 113kg (250lbs) of equipment - a durable solution for storing large, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
StarTech.com Server Rack Shelf - 1U - Adjustable Mount Depth - Heavy Duty rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.2 cm x 70 cm x 4.37 cm
5.4 kg
Adjustable depth, vented
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
48.2 cm
70 cm
4.37 cm
5.4 kg
Weight Limit
113.1 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
8875 StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.74
8875 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £77.58
8875 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £14.19
8875 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.10
8875 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.19
8875 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.15
8875 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.40
8875 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.51
8875 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £81.93
8875 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £85.10
8875 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £57.39
8875 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £62.63
8875 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £80.11
Price Range Ex VAT: 50 - 100
