Your basket is empty
StarTech.com 1U 20" High Resolution Folding Rackmount LCD Console for 19in Rack
Quicklinx: 7P1KWS00 Mfr#: RKCONS2001GB
The RKCONS2001GB 1U 20-inch High Resolution Folding Rack Mount LCD Console (for 19-inch racks) provides total KVM control right from your server rack, with a complete keyboard, monitor, mouse, and audio control point integrated into a space-efficient 1U of rack/cabinet space.
This durable and compact KVM Rack Console offers the largest (20.1-inches) and highest resolution (up to 1600x1200) TFT-LCD monitor available in a 1U rackmount design. When not in use, it can be folded and slid back into the server rack on sturdy mounting rails (included).
With the included cables, the LCD console can be connected to virtually any multi-port KVM switch for control of multiple servers/computers, providing a scalable solution that lets you determine the type of KVM switch to use. Plus, the console supports connection to PS/2, USB, VGA and DVI systems, accommodating both legacy and cutting edge computers.
StarTech.com High Res RackMount LCD Console for 19" Rack - LED monitor - 20.1"
LED-backlit LCD monitor - 20.1"
Keyboard, touchpad
Native Resolution
1600 x 1200
Pixel Pitch
0.255 mm
Contrast Ratio
1000:1
Response Time
15 ms
Colour Support
16.7 million colours
Input Connectors
VGA
60.8 cm x 4.4 cm x 44.8 cm
Height (Rack Units)
1U
15.5 kg
United Kingdom
UL, FCC, RoHS
2 years warranty
Display Type
Diagonal Size
20.1"
Native Resolution
1600 x 1200
Pixel Pitch
0.255 mm
Contrast Ratio
1000:1
Colour Support
Response Time
15 ms
Horizontal Viewing Angle
85
Vertical Viewing Angle
85
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
OSD Languages
English, German, French, Italian, Spanish
Height (Rack Units)
1U
15.5 kg
Input
Keyboard, touchpad
KVM
Max Resolution
1600 x 1200 @ 60 Hz
2 x USB , VGA , 2 x KVM (PS/2) , Audio line-in , DVI-I
1 x USB cable , 1 x audio cable , 1 x VGA cable
UL, FCC, RoHS
United Kingdom
Power Supply
External
AC 120/230 V
50 °C
10 - 90%
7P1K StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.73
7P1K StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £3.37
7P1K StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £3.42
7P1K StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £3.44
7P1K StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.30
7P1K StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £10.49
7P1K StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £8.89
7P1K StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F In Stock £3.52
7P1K StarTech.com 10ft USB Extension Cable A-A In Stock £3.75
7P1K StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £463.59
7P1K StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £3.65
