StarTech.com 1U 19" Rackmount LCD Console with 16 Port Multi-Platform KVM
Quicklinx: 5CBXWS00 Mfr#: RKCONS1916GB
This 1U Rack Mount LCD KVM Console features an integrated 16 Port Multi-Platform KVM Switch module, 19in active matrix LCD monitor, full 106-key keyboard and mouse touchpad neatly combined into 1U of space in any standard rack or cabinet 30in (or greater) in depth.
The KVM console offers a design similar to that of a rackmounted laptop computer - when the console is not in use, it's as simple as folding the LCD display and keyboard/mouse up and sliding it back into the server rack on the sturdy mounting rails (included).
A highly-scalable server control solution, each KVM console/switch module can control up to 136 computers by cascading 8 additional KVM switches. To ensure further versatility, the console is compatible with virtually any existing KVM switch as well as with most PC, Mac and Sun servers/systems.
StarTech.com LCD Rack Console - KVM console - 19"
KVM console - 19"
KVM Switch
PS/2 - 16 ports
Keyboard, touchpad
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
500:1
Response Time
12 ms
44 cm x 53 cm x 4.4 cm
Height (Rack Units)
1U
12 kg
United Kingdom
UL, FCC, RoHS
P/N: 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
Display Type
KVM console / TFT active matrix
Diagonal Size
19"
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
500:1
Response Time
12 ms
Horizontal Viewing Angle
140
Vertical Viewing Angle
140
Height (Rack Units)
1U
12 kg
Input
Keyboard, touchpad
KVM
KVM switch - 16 ports
Keyboard / Mouse Interface
PS/2
Max Resolution
1280 x 1024
Max Cascading Depth
9
16 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x keyboard - 6 pin mini-DIN (PS/2 style) , 1 x mouse - 6 pin mini-DIN (PS/2 style)
UL, FCC, RoHS
United Kingdom
Power Supply
External
Microsoft DOS, HP-UX, Microsoft Windows 3.1, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP
50 °C
10 - 90%
5CBX StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £7.06
5CBX StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £10.59
5CBX StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £7.49
5CBX StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £15.89
Resources
The following resources are available for the StarTech.com 1U 19" Rackmount LCD Console with 16 Port Multi-Platform KVM
