StarTech.com 1U 19" Cable Management Panel
Quicklinx: BGC6WS00 Mfr#: CMPNL1UC
£51.49 ex VAT
£61.78 inc VAT
Keep horizontal and vertical cabling organized, with this combination panel of finger ducts and D-ring hooks. Keeping cables organized makes it easier to manage your server room or data center. This one-piece organizer with 1U design helps you keep all of your cables accessible and identifiable, for a tidier, more scalable server workspace.
All you need to install the cable organizer is 1U of available rack space. It makes it easier to manage cables from the front or back of your server rack, with conveniently placed hooks that hold both vertically and horizontally running cables.
The organizer helps you manage network, server and KVM cabling in your server rack by utilizing a combination of horizontal finger ducts and vertical or horizontal D-ring hooks. It organizes and guides cable using 12 lockable clips to keep cables securely in place.
Engineered with high-quality steel construction and sturdy hooks, the cable organizer is built to deliver dependable performance, year after year.
Adding the cable organizer in between your equipment also closes off open spaces in the rack, which promotes proper airflow. By relieving cable strain, it also increases the lifespan of your server and networking equipment interfaces.
Note: The hooks on this cable management system extend past 19 inches. As a result certain racks with close spaced or inset rack mount holes may not be compatible with this product.
  • Easy cable organization for a more manageable server room
  • Durable construction ensures dependable performance
StarTech.com Server Rack Cable Management - 1U - Finger Ducts / D-Ring Hooks - rack cable management panel with cover - 1U
Rack cable management panel with cover
Rack Size
19"
Height (Rack Units)
1U
Product Material
Steel
51 cm x 10.2 cm x 4.4 cm
800 g
Horizontal orientation
P/N: RKCONS1708K, RKCONS1716K
Product Material
Steel
Rack Size
19"
Height (Rack Units)
1U
51 cm
10.2 cm
4.4 cm
800 g
RoHS
Limited warranty: - 2 years
