Control up to 16 servers or KVM switches with this 1U rack-mountable LCD console. The RACKCONS1716GB 1U 17-inch Rack Mount LCD Console features an integrated 16-Port KVM Switch, to provide centralized control for servers and KVM switches with a 17-inch LCD monitor, full 106-key keyboard and touchpad neatly combined into 1U of space in any standard rack or cabinet (30-inches or greater) in depth. A secure solution, the rack-mount console includes a key-lock mechanism as well as individual port password protection for preventing unauthorized access. When not in use, it's as simple as folding the LCD display and sliding it back into the rack on the sturdy mounting rails (included). A highly-scalable server control solution, the rack console can control up to 136 computers by cascading 8 additional 16 port KVM switches. For added versatility, the console is compatible with virtually any existing KVM switch as well as with most PC, Mac and Sun systems.
- StarTech.com LCD Console with 16 Port KVM Switch Integrated - KVM console - 17"
- KVM console - 17"
- KVM Switch
- PS/2 - 16 ports
- Keyboard, touchpad
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 450:1
- Response Time
- 16 ms
- Voltage
- AC 120/230 V
- 44 cm x 47 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 11.8 kg
- Localisation
- United Kingdom
- UL, cUL, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 450:1
- Response Time
- 16 ms
- Horizontal Viewing Angle
- +60 / -70
- Vertical Viewing Angle
- +45 / -60
- 1U
- 11.8 kg
Input
KVM
- KVM switch - 16 ports
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1280 x 1024
- 16 x VGA , VGA output , Keyboard (PS/2) , Mouse (PS/2)
- Localisation
- United Kingdom
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 25 Watt
- OS Required
- Microsoft DOS, HP-UX, Microsoft Windows 3.1, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £7.06 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.59 |
StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable | In Stock | £7.49 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £15.89 |
