StarTech.com 1U 17" Rackmount LCD Console with 8 Port Multi-Platform KVM
Quicklinx: 5CBWWS00 Mfr#: RKCONS1708GB
This 1U Rack Mount LCD KVM Console features an integrated 8 Port Multi-Platform KVM Switch module, 17in active matrix LCD monitor, full 106-key keyboard and mouse touchpad neatly combined into 1U of space in any standard rack or cabinet 30in (or greater) in depth.
The KVM console offers a design similar to that of a rackmounted laptop computer - when the console is not in use, it's as simple as folding the LCD display and keyboard/mouse up and sliding it back into the server rack on the sturdy mounting rails (included).
A highly-scalable server control solution, each KVM console/switch module can control up to 64 computers/servers by cascading 8 additional KVM switches. To ensure further versatility, the console is compatible with virtually any existing KVM switch as well as with most PC, Mac and Sun servers/systems.
StarTech.com LCD Console w/8 Port Multi-Platform KVM - KVM console - 17"
KVM console - 17"
KVM Switch
PS/2 - 8 ports
Keyboard, touchpad
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
450:1
Response Time
16 ms
44 cm x 47 cm x 4.4 cm
Height (Rack Units)
1U
11 kg
United Kingdom
UL, FCC, RoHS
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
450:1
Response Time
16 ms
Horizontal Viewing Angle
+60 / -70
Vertical Viewing Angle
+45 / -60
Height (Rack Units)
1U
11 kg
Input
Keyboard, touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
PS/2
Max Resolution
1280 x 1024
8 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x keyboard - 6 pin mini-DIN (PS/2 style) , 1 x mouse - 6 pin mini-DIN (PS/2 style)
UL, FCC, RoHS
United Kingdom
Power Supply
External
Microsoft DOS, HP-UX, Microsoft Windows 3.1, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP
50 °C
10 - 90%
5CBW StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.74
5CBW StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.75
5CBW StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £6.47
Resources
The following resources are available for the StarTech.com 1U 17" Rackmount LCD Console with 8 Port Multi-Platform KVM
