This 1U Rack Mount LCD KVM Console features an integrated 8 Port Multi-Platform KVM Switch module, 17in active matrix LCD monitor, full 106-key keyboard and mouse touchpad neatly combined into 1U of space in any standard rack or cabinet 30in (or greater) in depth.
The KVM console offers a design similar to that of a rackmounted laptop computer - when the console is not in use, it's as simple as folding the LCD display and keyboard/mouse up and sliding it back into the server rack on the sturdy mounting rails (included).
A highly-scalable server control solution, each KVM console/switch module can control up to 64 computers/servers by cascading 8 additional KVM switches. To ensure further versatility, the console is compatible with virtually any existing KVM switch as well as with most PC, Mac and Sun servers/systems.
- StarTech.com LCD Console w/8 Port Multi-Platform KVM - KVM console - 17"
- KVM console - 17"
- KVM Switch
- PS/2 - 8 ports
- Keyboard, touchpad
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 450:1
- Response Time
- 16 ms
- 44 cm x 47 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 11 kg
- Localisation
- United Kingdom
- UL, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 450:1
- Response Time
- 16 ms
- Horizontal Viewing Angle
- +60 / -70
- Vertical Viewing Angle
- +45 / -60
- 1U
- 11 kg
Input
KVM
- KVM switch - 8 ports
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1280 x 1024
- 8 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x keyboard - 6 pin mini-DIN (PS/2 style) , 1 x mouse - 6 pin mini-DIN (PS/2 style)
- UL, FCC, RoHS
- Localisation
- United Kingdom
- Power Supply
- External
- OS Required
- Microsoft DOS, HP-UX, Microsoft Windows 3.1, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £7.06 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.60 |
StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable | In Stock | £7.49 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £15.89 |
