Control server equipment from a centralized, Full HD KVM console. The RKCONS17HDGB 17" Full HD LCD Rack Console lets you control server equipment from a centralized, 17in 1080p KVM console, with an integrated 2-port front USB hub.
The integrated single port KVM module offers universal support for DVI or VGA, and USB or PS/2 console connections and includes all of the necessary cabling to get you up and running. Connect the console to either a single system, or a multi-port KVM switch to manage multiple systems.
The front panel USB hub places two easily accessible USB 2.0 ports at your disposal for connecting external storage and other peripherals as needed.
For added security in your server room, this rackmount LCD also includes a physical key-lock.
- StarTech.com 1U 17" HD 1080p Rackmount LCD Console with Front USB Hub - KVM console - Full HD (1080p) - 17"
- KVM console - 17"
- KVM Switch
- PS/2, USB
- Keyboard, touchpad
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-I, VGA
- Voltage
- AC 120/230 V
- Black
- 44.8 cm x 46 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 13 kg
- Localisation
- United Kingdom
- FCC, RoHS
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 120
- Backlight Technology
- LED backlight
- Black
- 1U
- 13 kg
Input
KVM
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1920 x 1080 / 1080p
- 2 x USB 2.0 (Type A) , Keyboard (PS/2) , Mouse (PS/2) , Keyboard (USB) , Mouse (USB) , DVI-I , VGA (HD-15)
- Key lock
- Cables Included
- 1 x USB cable - 1.8 m , 1 x keyboard / mouse / video cable - 1.8 m
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- FCC, RoHS
- Localisation
- United Kingdom
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 23.35 Watt
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £551.61 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £292.31 |
