The RACKCOND1701 1U 17-inch Rack Mount LCD Console Drawer offers a high resolution LCD display, full keyboard and touchpad console, allowing you to centrally manage and monitor your servers and KVM switches using a space-saving 1U of rack space.
The LCD Console drawer features an innovative dual-rail system that allows the display to slide independently from the keyboard/touchpad tray, giving system administrators the ability to use the device as a monitoring station while the keyboard is neatly tucked away inside the rack. Unlike other 17-inch LCD Rack Consoles, this unit supports VGA resolutions up to 1920x1080, ensuring crystal clear high definition display of even the most demanding server room applications.
The Rack Console features an integrated single port KVM module enabling direct connections to a single system or to KVM switches in a cascaded configuration for centralized control of multiple systems.
- StarTech.com HD 1080p Dual Rail RackMount Widescreen LCD Console - KVM console - Full HD (1080p) - 17.3"
- KVM console - 17.3"
- KVM Switch
- PS/2
- Keyboard, touchpad
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.199 mm
- Contrast Ratio
- 500:1
- Response Time
- 8 ms
- Input Connectors
- VGA
- Black
- 68 cm x 4.4 cm x 48.1 cm
- Height (Rack Units)
- 1U
- 15.6 kg
- FCC, RoHS
- 3-year warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17.3"
- Native Resolution
- Pixel Pitch
- 0.199 mm
- Contrast Ratio
- 500:1
- Response Time
- 8 ms
- Horizontal Viewing Angle
- 70
- Vertical Viewing Angle
- 60
- Black
- 1U
- 15.6 kg
Input
KVM
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1920 x 1080
- Keyboard (PS/2) , Mouse (PS/2) , VGA , USB (Type B)
- FCC, RoHS
- Power Supply
- External
- Voltage Required
- AC 120/230 V
- Power Consumption (Typical)
- 16 Watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
