Brand
StarTech.com 1U 17" HD 1080p Dual Rail Rackmount Widescreen LCD Console
Quicklinx: 7P17WS00 Mfr#: RACKCOND1701
Hurry, only 1 left in stock!
£875.45 ex VAT
£1,050.54 inc VAT
The RACKCOND1701 1U 17-inch Rack Mount LCD Console Drawer offers a high resolution LCD display, full keyboard and touchpad console, allowing you to centrally manage and monitor your servers and KVM switches using a space-saving 1U of rack space.
The LCD Console drawer features an innovative dual-rail system that allows the display to slide independently from the keyboard/touchpad tray, giving system administrators the ability to use the device as a monitoring station while the keyboard is neatly tucked away inside the rack. Unlike other 17-inch LCD Rack Consoles, this unit supports VGA resolutions up to 1920x1080, ensuring crystal clear high definition display of even the most demanding server room applications.
The Rack Console features an integrated single port KVM module enabling direct connections to a single system or to KVM switches in a cascaded configuration for centralized control of multiple systems.
StarTech.com HD 1080p Dual Rail RackMount Widescreen LCD Console - KVM console - Full HD (1080p) - 17.3"
KVM console - 17.3"
KVM Switch
PS/2
Keyboard, touchpad
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.199 mm
Contrast Ratio
500:1
Response Time
8 ms
Input Connectors
VGA
Voltage
AC 120/230 V
68 cm x 4.4 cm x 48.1 cm
Height (Rack Units)
1U
15.6 kg
FCC, RoHS
3-year warranty
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK3236BKF, RK4236BK, RK4242BK
Display Type
KVM console / TFT active matrix
Diagonal Size
17.3"
Native Resolution
Pixel Pitch
0.199 mm
Contrast Ratio
500:1
Response Time
8 ms
Horizontal Viewing Angle
70
Vertical Viewing Angle
60
Height (Rack Units)
1U
15.6 kg
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
PS/2
Max Resolution
1920 x 1080
Keyboard (PS/2) , Mouse (PS/2) , VGA , USB (Type B)
FCC, RoHS
Power Supply
External
Input Voltage
AC 120/230 V
Power Consumption (Typical)
16 Watt
Limited warranty - 3 years
0 - 80%
7P17 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £532.60
7P17 StarTech.com 1U 17" HD 1080p Dual Rail Rackmount Widescreen LCD Console In Stock £875.45
7P17 StarTech.com DC Power Adapter - 12V, 5A In Stock £45.71
7P17 StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,167.23
7P17 StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,263.12
Type: Rackmount LCD Monitor
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
