Control server equipment from a Full HD KVM console, with a convenient dual-rail slide design. The RKCOND17HDGB Dual Rail LCD Rack Console lets you control server equipment from a centralized, 17in 1080p KVM console, with an integrated 2-port front USB hub and fingerprint reader.
The dual-rail system allows the display to slide independently from the keyboard/touchpad tray, enabling you to use the console as a monitoring station while the keyboard is stored in the rack.
The integrated single port KVM module offers universal support for DVI or VGA, and USB or PS/2 console connections and includes all of the necessary cabling to get you up and running. Connect the console to either a single system, or a multi-port KVM switch to manage multiple systems. Plus, the front panel USB hub places two easily accessible USB 2.0 ports at your disposal for connecting external storage and other peripherals as needed.
This rackmount LCD also includes a physical key-lock and a bio-metric fingerprint reader to provide an extra layer of security in your server room. The fingerprint reader can be configured for access control, application/file launching and also to create and access virtual secure storage drives for different users.
- StarTech.com 1U 17" HD 1080p Dual Rail Rackmount LCD Console w/ Fingerprint Reader and Front USB Hub - KVM console - Full HD (1080p) - 17"
- KVM console - 17"
- KVM Switch
- PS/2, USB
- Keyboard, touchpad, fingerprint reader
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-I, VGA
- Voltage
- AC 90 - 240 V
- Black
- 44.8 cm x 46 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 13 kg
- FCC, RoHS
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Built-in Devices
- Fingerprint reader
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 120
- Black
- 1U
- 13 kg
Input
KVM
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1920 x 1080 / 1080p
- DVI-I , VGA (HD-15) , 2 x USB (Type A) , Keyboard (PS/2) , Mouse (PS/2)
- Key lock
- Cables Included
- 1 x DVI cable , 1 x keyboard / mouse / video cable , 1 x USB cable
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- FCC, RoHS
- Power Supply
- External
- Input Voltage
- AC 90 - 240 V
- Power Consumption (Typical)
- 23.35 Watt
- Included Software
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
