StarTech.com 1S1P Native PCI Express Parallel Serial Combo Card with 16950 UART
Quicklinx: 7P11WS00 Mfr#: PEX1S1P952
Type: Parallel/serial adapter
Compatibility: PC
Interface: PCI Express
10 in stock
£31.15 ex VAT
£37.38 inc VAT
The PEX1S1P952 1S1P native PCI Express parallel/serial combo card with 16950 UART turns a PCI Express slot into 1 RS232 (DB9) serial, and 1 parallel port.
The combo card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards that use a bridge chip design.
This 1-port serial/1-port parallel card offers compatibility with a broad range of operating systems, for easy integration into mixed environments.
StarTech.com 1S1P Native PCI Express Parallel Serial Combo Card with 16950 UART - parallel/serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 1.1
12 cm x 8 cm x 6.5 cm
60 g
Parallel, RS-232
Microsoft Windows 2000 Server, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
PCI Express
PCIe 1.1
Wired
Parallel, RS-232
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
WHQL, FCC, RoHS
12 cm
8 cm
6.5 cm
60 g
Limited warranty - lifetime
-40 °C
85 °C
0 - 60%
7P11 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
7P11 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
7P11 StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £5.93
7P11 StarTech.com 6 ft Parallel Printer Cable In Stock £3.64
7P11 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
7P11 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: PC
Price Range Ex VAT: 0 - 50
