The PEX1S1P952 1S1P native PCI Express parallel/serial combo card with 16950 UART turns a PCI Express slot into 1 RS232 (DB9) serial, and 1 parallel port.
The combo card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards that use a bridge chip design.
This 1-port serial/1-port parallel card offers compatibility with a broad range of operating systems, for easy integration into mixed environments.
- StarTech.com 1S1P Native PCI Express Parallel Serial Combo Card 16950 (PEX1S1P952) - parallel/serial adapter - PCIe
- Parallel/serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- PCI Specification Revision
- PCIe 1.1
- 12 cm x 8 cm x 6.5 cm
- 60 g
- Data Link Protocol
- Parallel, RS-232
- System Requirements
- Microsoft Windows 2000 Server, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- Limited lifetime warranty
- Form Factor
- PCI Express
- PCIe 1.1
- Connectivity Technology
- Wired
- Parallel, RS-232
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express
- WHQL, FCC, RoHS
- OS Required
- 12 cm
- 8 cm
- 6.5 cm
- 60 g
- Limited warranty - lifetime
- -40 °C
- 85 °C
- 0 - 60%
StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART | In Stock | £37.05 |
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART | In Stock | £35.75 |
StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART | In Stock | £34.33 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
