Product
Brand
StarTech.com 1S1P Mini PCI Express Serial Parallel Card w/ 16950 UART
Quicklinx: 6BDSWS00 Mfr#: PEX1S1PMINI
This Mini PCI Express 1S1P serial/parallel card turns a mini PCIe slot into one RS232 (DB9) serial port and one Parallel port.
The adapter card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards which use a bridge chip design.
Compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and Mac OS 10.4, the mini-PCI Express Serial/Parallel Card also features an optional low profile bracket that allows the card to be installed in virtually any computer case, regardless of the case form factor.
The mini PCIe Parallel/Serial combo card offers a cost-saving solution for adding legacy serial and parallel support for embedded systems that aren't normally compatible.
The mini-PCI Express Parallel/Serial card is designed and constructed to provide long-lasting durability and reliability.
StarTech.com 1S1P Mini PCI Express Serial Parallel Card w/ 16950 UART - parallel/serial adapter - 2 ports
Parallel/serial adapter
Plug-in card
Interface (Bus) Type
PCI Express Mini Card
PCI Specification Revision
PCIe 1.1
5 cm x 3 cm x 0.6 cm
6.2 g
Ports Qty
2 ports
Parallel, serial
Data Transfer Rate
460.8 Kbps
Apple MacOS X 10.4, Linux Kernel 2.6.11 or later, Microsoft Windows 2003, Microsoft Windows Vista / 2000 / XP
Parallel/serial adapter - 2 ports
Plug-in card
PCIe 1.1
Wired
Parallel, serial
Data Transfer Rate
460.8 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1 (external) , 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) (external)
Compatible Slots
1 x PCI Express Mini Card
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
5 cm
3 cm
0.6 cm
6.2 g
Limited warranty - lifetime
-40 °C
85 °C
5 - 85%
6BDS StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
6BDS StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
6BDS StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.88
6BDS StarTech.com DB9 to RJ45 Modular Adapter - F/F In Stock £4.16
6BDS StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F In Stock £5.95
6BDS StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £5.93
6BDS StarTech.com 6 ft Parallel Printer Cable In Stock £4.55
