Extend the length of your USB 2.0 cable by up to 1m. The USBEXTPAA1MW 1m White USB 2.0 Extension Cable features a USB ''A'' male connector and a USB ''A'' female connector, enabling you to extend the connection distance between your USB 2.0 devices by up to 1-meter - allowing for better placement of your peripheral devices, or adding flexibility to your existing USB ports.
The cable features thin USB connector moldings which allow you to simplify your connections, and plug into tight fitting locations.
- StarTech.com 1m White USB 2.0 Extension Cable Cord - A to A - USB Male to Female Cable - 1x USB A (M), 1x USB A (F) - White, 1 meter (USBEXTPAA1MW) - USB extension cable - USB to USB - 1 m
- Technology
- Double shielded
- Molded, strain relief
- Length
- 1 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- White
- Limited lifetime warranty
- Designed For
- P/N: MSDREADU2OTG, USBEXTPAA2MW, USBEXTPAA3MW, USBPAUB1MW, USBPAUB2MW, USBPAUB50CMW, UUSBOTG
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 1 m
- White
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.27 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £4.52 |
StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F | In Stock | £4.91 |
StarTech.com 1m White Micro USB Cable - A to Micro B | In Stock | £2.91 |
StarTech.com 2m White Micro USB Cable - A to Micro B | In Stock | £5.13 |
StarTech.com 0.5m White Micro USB Cable - A to Micro B | In Stock | £2.60 |
