Brand
StarTech.com 1m USB C to DP Cable - White
Quicklinx: D4SQWS00 Mfr#: CDP2DPMM1MW
£23.84 ex VAT
£28.60 inc VAT
Use this USB-C to DP cable to connect your USB Type C computer directly to a monitor without additional adapters. This USB-C to DisplayPort cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 1 m (3 ft.) away.
The adapter works with USB-C devices that support DP Alt Mode, such as the MacBook, ChromeBook Pixel, and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this DisplayPort cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. Plus, the USB-C cable's all-white design makes it an attractive accessory for your HP ENVY or MacBook with USB-C. If you're looking for a longer white USB-C to DisplayPort cable, StarTech.com also offers a White 1.8 m (6 ft.) USB-C to DP Cable (CDP2DPMM6W).
While the adapter looks great next to computers like your Mac and HP ENVY, it works with any USB-C computer that supports DisplayPort Alt Mode, such as your Dell XPS, Ultrabook or other Windows laptop. But if you're looking for a black cable to match your workstation, StarTech.com offers a full line of black USB-C to DisplayPort cables including: a Black 1 m (3 ft.) USB-C to DP cable (CDP2DPMM1MB), and a Black 1.8 m (6 ft.) USB-C to DP cable (CDP2DPMM6B), enabling you to choose the right color and cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower resolution displays, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
Your USB-C equipped device must support video (DP Alt Mode) to work with this adapter.
StarTech.com 3ft/1m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Compatible with Thunderbolt 3, White - USB-C Male to DP Male (CDP2DPMM1MW) - external video adapter - STM32F072CBU6 - white
External video adapter
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160
DisplayPort (male connector)
2 cm 1 cm
Length
1 m
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160 at 60 Hz
HD/4k Ready, 7.1 channel surround sound ready, Thunderbolt 3 compatible
FCC, RoHS, WEEE
2 cm
1 cm
Length
1 m
35 g
Enclosure Colour
White
Limited warranty - 3 years
20 - 70%
D4SQ StarTech.com 6ft USB-C to DisplayPort Cable In Stock £27.71
D4SQ StarTech.com 2m USB-C to HDMI Cable In Stock £28.60
D4SQ StarTech.com 1m USB-C to HDMI Cable In Stock £25.80
D4SQ StarTech.com 1m USB-C to VGA Cable In Stock £27.92
D4SQ StarTech.com 2m USB-C to VGA Cable In Stock £28.95
D4SQ StarTech.com 1m USB C to DP Cable - White In Stock £23.84
D4SQ StarTech.com 6 ft USB C to DP Cable - White In Stock £27.86
D4SQ StarTech.com 3m USB C to DisplayPort Cable - White In Stock £29.38
D4SQ StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £29.08
D4SQ StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £28.42
D4SQ StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £34.11
Stock Status: In stock
