StarTech.com 1m QSFP+ Breakout Cable
Quicklinx: D9TWWS00 Mfr#: QSFP4SFPPC1M
Select:
Connect four MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications, such as point-to-point, in-rack network switch or server connections, for up to four 10G SFP+ devices.
StarTech.com MSA Uncoded Compatible 1m 40G QSFP+ to 4x SFP+ Direct Attach Breakout Cable Twinax, 40GbE QSFP+ to 4x SFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC Cable - Lifetime Warranty (QSFP4SFPPC1M) - breakout cable - 1 m - black
Breakout cable - SFF-8431/SFF-8432/SFF-8436
Twinaxial
Passive cable
Length
1 m
Connector
QSFP+ - latched
Connector (Second End)
4 x SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
1 m
72 g
Connector
QSFP+ - latched
4 x SFP+ - latched
FCC, RoHS, MSA
70 °C
D9TW StarTech.com 3m QSFP+ Breakout Cable In Stock £136.64
