Product
StarTech.com 1m Pro Series Metal High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 9X8XWS00 Mfr#: HDPSMM1M
Length: 1m
Select:
45 in stock
£8.38 ex VAT
£10.05 inc VAT
Standard delivery Delivered within 3-5 working days
Create stylish and durable Ultra HD connections between your High Speed HDMI-equipped devices, for the ultimate home theater experience. The HDPSMM1M Pro Series High Speed HDMI cable (1m) features 2 gold-plated HDMI (male) connectors inside a metal connector molding, providing durable, high quality connections with a stylish look that offer the perfect finish for your home theater or professional A/V environment.
This 1-meter, lightweight HDMI cable also features thinner HDMI wire construction - roughly half the thickness of a regular 1m cable, which allows for a more flexible installation with minimal clutter.
This high-end HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 1m Pro Series Metal High Speed HDMI Cable - Ultra HD 4k x 2k - HDMI cable - 1 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
36
Length
1 m
Connector
Micro HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI cable - 4K support
Double shielded
36
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Gold
Moulded
Connector
19 pin micro HDMI Type D - male
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 1m
Price Range Ex VAT: 0 - 50
