Provide a high-speed, crystal-clear connection to your DVI digital devices. The DVIDSMM1M DVI-D Single Link cable features 2 male DVI (19-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 1m DVI-D male to male cable supports resolutions of up to 1920x1200 and transmission rates of up to 4.95 Gbits/sec, and is fully compliant with DVI DDWG standards.
- StarTech.com 1m DVID Single Link Cable M/M - DVI cable - 1 m
- DVI cable - single link
- Technology
- Double shielded
- Molded, thumbscrews
- Length
- 1 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Single link
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
