StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
Quicklinx: 8JFLWS00 Mfr#: SFPCMM1M
Length: 1m
21 in stock
£29.48 ex VAT
£35.37 inc VAT
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU1M cable. The SFPCMM1M Cisco Compatible 1m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU1M cable.
StarTech.com Cisco SFP-H10GB-CU1M Comp SFP+ DAC Cable - 1 m (3.3 ft.) - direct attach cable - 1 m
Direct attach cable
Twinaxial
Latching connectors
Length
1 m
Connector
SFP+
Connector (Second End)
SFP+
Cisco Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48; Nexus 93180, 9336, 9372; UCS 6140
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
1 m
Connector
SFP+
SFP+
RoHS
70 °C
Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S , Cisco Nexus 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco UCS 6140XP Fabric Interconnect
Length: 1m
Price Range Ex VAT: 0 - 50
