StarTech.com 1m Blue Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
Quicklinx: 9TVGWS00 Mfr#: USBAUB1MBL
Length: 1m
42 in stock
£4.46 ex VAT
£5.35 inc VAT
Charge and Sync your Micro USB-equipped Smartphone or Tablet. Tired of the same old boring black cables? Want something that matches your personality?
The USBAUB1MBL 1m Blue Micro USB Cable is perfect for adding a little color to your life, and for providing a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The cable is colored to suit your blue mobile devices but it can be used with any of your Micro USB-enabled mobile devices - so don't be afraid to be colorful and select from any of the colored Micro USB cables such as USBAUB1MPK Pink, USBAUB1MGN Green, USBAUB1MYL Yellow or Blue. You can create the perfect color match with your smartphone or tablet or be creative with your own unique look!
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
StarTech.com Micro-USB cable - 1m, blue - USB cable - 1 m
USB cable
Double shielded
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
Blue
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Blue
Connector
USB / USB 2.0, RoHS
9TVG StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M In Stock £3.79
9TVG StarTech.com 1m Blue Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.46
9TVG StarTech.com 1m Green Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.33
9TVG StarTech.com 1m Pink Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.33
9TVG StarTech.com 1m Yellow Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.33
Length: 1m
Price Range Ex VAT: 0 - 50
