StarTech.com 1m Black DB9 Null Modem Cable
Quicklinx: B149WS00 Mfr#: SCNM9FF1MBK
Length: 1m
Select:
27 In Stock
£3.93 ex VAT
£4.71 inc VAT
Connect your serial devices, and transfer your files. The SCNM9FF1MBK 1m DB9 Null Modem Cable features two DB9 female connectors, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC to PC via a serial connection.
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/F - DB9 Female to Female - 9 pin RS232 Null Modem Cable - 1 meter, Black - null modem cable - DB-9 to DB-9 - 1 m
Null modem cable
Molded, thumbscrews, EMI protection
Length
1 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: PCI2S5502, PEX4S953, PEX4S953LP
Null modem cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
RoHS
B149 StarTech.com 1m Black DB9 Null Modem Cable In Stock £3.93
B149 StarTech.com 2m Black DB9 Null Modem Cable In Stock £4.52
B149 StarTech.com RS232 Serial Null Modem Cable In Stock £7.64
Length: 1m
